  2. Functional Verification
  3. pre_body() and post_body() from virt-seq
  • Subscribers 66
  • Views 19315
archive over 18 years ago
Hi there,
I implemented my objection handling "raise_objection" in pre_body() and "drop_objection" in post_body() so I don't have to worry about the test stopping during some sequence. When I "do" my sequences from a sve virtual_seq, the pre_body() and post_body() functions are not called whereas when I "do" my sequences from the MAIN eVC sequence, both are called.
Is this intended behaviour?
My workaround currently is calling pre_body() as first statement in body() itself and post_body at the very end.
The fact that calling them works tells me, that they are present.
Shouldn't they be called automatically by the virtual sequence before and after the body() section?
greetings
Originally posted in cdnusers.org by SomeDude
    Hi Dude,
    To be on the safe side, did you declare your virtual sequence driver with the sequence-macro to create the sequence infrastructure, or if you didn't, did you let your sequence like-inherit from any_sequence?
    Hilmar
    Originally posted in cdnusers.org by Hilmar
    I believe pre_body() is called only when you start your sequence using start_sequence(), which is not so common.
    So if you're "DO"ing your sequence - it won't work.
    However, if I remember correctly- MAIN sequences are started automatically with "start_sequence()" so pre_body() should work for themt, but as for other sequence kinds - you might want to look into the pre_do() tcm.
    Hope this help :-)
    Yaron
    Originally posted in cdnusers.org by thinkverification
    In this case i you can implement the objection mechanism by raising the TEST_DONE objection from the virtual sequence pre_body() and dropping it from the virtual sequence post_body().
    Hope this will help to you.
    Gaurav Patel
    ASIC Engineer
    eInfochips.
    www.einfochips.com
    Originally posted in cdnusers.org by er_gauravpatel
    Thx for the help guys!
    Posted By Hilmar on 2/05/2008 5:23 AM
    I used the macro.
    Posted By thinkverification on 2/05/2008 6:45 AM
    thx for the tip, I scavanged around in some older documents we had and found the mid_do() and post_do() hooks. Using those I now raise and drop objections in the driver itself. I think pre_do() is done before the pointers are connected. I failed to find this whole pre_do/mid_do/post_do in the latest documents though, only in some 4.something version.
    Posted By er_gauravpatel on 2/05/2008 10:39 AM
    That was already implemented and didn't fully do it. As soon as the virtual sequence was finished, the test stopped, but the subsequences were not fully done yet. The stimulus was done, but the collecting agents were not completely done. As result, scoreboards were still full and the dut wasn't done digesting the input. Hence I also put objections into the collecting agents that once they found some data stream they keep the objection it up till they are done as well.
    greetings
