  2. Functional Verification
  3. how to generate again a struct variable:
  • Subscribers 66
  • Views 14855
archive over 18 years ago
Hello, i'd like to make a constraint to variable, in a post_generate() phase, and generate this variable under this constraint. after that, i'd like set this variable a new constraint in run() phase, and generate this variable once again accordingly. is this possible ? here's a pseudo code example : struct A X:uint; post_generate() is also { keep A.X 5; gen A.X; }
Originally posted in cdnusers.org by zcabeli11
    Seems like you're using "keep" instead of "keeping".
    Try to use "gen A.x keeping {..."
    Yaron
    Originally posted in cdnusers.org by thinkverification
