  2. Functional Verification
  3. access to distint unit data member ...
  • Subscribers 66
  • Views 14959
archive over 18 years ago
i've got a question which is not essential, but still can prevent redefinision in my code. i'd like to use a port in my struct, which is previously defined in another unit. the current hierarchy is as follows : sys.struct sys.unit perhaps i should include my struct from the unit, so i could have access to this data member...
Originally posted in cdnusers.org by zcabeli11
    It' s not recommended to place your components directly under sys, but technically speaking you could access the port simply by giving the full path (sys.xxx...)
    Better alternatives would be to create a parent-son hierarchy (like you suggessted) or interconnect the two by pointers ("brothers"). The chosen topology depends on your application.
    Yaron
    Originally posted in cdnusers.org by thinkverification
