  2. Functional Verification
  3. Generate a list of unique numbers
  • Replies 7
  • Subscribers 66
  • Views 17148
archive over 18 years ago
How do you generate a list with unique numbers? Lets say I have a list of n element of type uint. I now want to generate the list with random numbers but the same number are not allowed to be in the list twice.
my_list[n]: list of uint;
Originally posted in cdnusers.org by ryz
    This is the way I've been told:
    channels : list of byte;
    keep channels in all_values(byte[0..255]);
    keep channels.size() == 10;
    /Ed
    Originally posted in cdnusers.org by earthur
    I expect this will also work:
    keep for each in my_list {
    index > 0 => it not in my_list[0..(index-1)];
    Dean
    Originally posted in cdnusers.org by ddmello
    Dean,
    That one is good for small values of N.
    Above the 'Y should be "[ 0".
    /Ed
    Thanks for clarifying Ed. Sounds like you've been down this road before :-)
    BTW the [0 / 'Y thing happened with your post as well; apparently we need to use delimiters to prevent that.
    So for correctness your solution is:
    <code>
    </code>
    Dean
    Thanks for clarifying, Ed. Sounds like you've been down this road before :-) BTW the 'Y problem occurred for your post as well, a note "Posting Code to the Forum" describes how to prevent this when posting code. So for correctness your solution should read: channels : list of byte; keep channels in all_values(byte[0..255]); keep channels.size() == 10; and my code (for small list sizes) should be: keep for each in my_list { index > 0 => it not in my_list[0..(index-1)]; }; Regards, Dean
    Here's anther idea..
    lb: list of byte;
    keep lb.is_a_permutation(all_values(byte[0..9]));
    Yaron
    Originally posted in cdnusers.org by thinkverification
    Posted By thinkverification on 2/14/2008 12:24 AM
    lb: list of byte;
    Yaron
    Again: Y === [0 :-)
