  2. Functional Verification
  3. Difference between instance and reference
  • Subscribers 66
  • Views 15834
archive over 18 years ago
Hello... What is the difference between instantiating and referencing the struct or a unit in 'e'? Ex. unit abc {}; struct xyz {}: abc_r : abc; (Reference) abc_i : abc is instance; (instance) or xyz_r : xyz; (Reference) xyz_i : xyz is instance; (instance) So, What is the difference between Reference and Instance? Thanks!
Originally posted in cdnusers.org by vlsi_dude
    Units are like a static struct, they can only be generated during pre-run generation and they have
    a static path in the hierarchy (e-path) which doesn't change during a run (units have other specific attributes
    like hdl_path()). The recommendation is to use units to model static test bench components (monitors,
    BFMs, sequence drivers etc.) which are valid throughout the test.
    structs can be dynamically generated (on the fly), they don't have a static e-path etc.
    abc_r : abc; (Reference) -> reference(pointer) to a static unit
    abc_i : abc is instance; (instance) -> static unit instance
    xyz_r : xyz; (Reference) -> this is a struct instance, not a reference
    xyz_i : xyz is instance; (instance) -> this is an error, can not be done
    to get a reference to xyz_r you could do:
    var xyz_ref: xyz;
    xyz_ref = xyz_r;
    (xyz_ref was not generated and just assigned, so it is a reference to xyz_r)
    In general assignments of structs to other structs are done by reference. After the assignment
    takes place, the variable on the left side refers to the same instance that was referred to by the
    expression on the right side.
    -hannes
    Originally posted in cdnusers.org by hannes
