  2. Functional Verification
  3. printing struct members:
  • Subscribers 66
  • Views 16909
archive over 18 years ago
Hello, i've got a struct with planty of data members, and some methods. i'd like to be able to print all members automatically (without specify each one in particular). i.e. struct X{ A:uint; B:string; C:bool; D:uint; ... }; the function 'print X' will produce: " A = ... B = ... ... " thanks,
Originally posted in cdnusers.org by zcabeli11
    you can use the built-in print function:
    Specman s> print sys.s
    sys.s = s-@0: s of unit: sys
    ---------------------------------------------- @s
    0 a: 1840385568
    1 b: FALSE
    2 c: 1554590122
    3 d: ""
    from within your code you can use "print me;".
    Nils
    Originally posted in cdnusers.org by nls
    Hi....... You can print struct field by taking instance of that struct and printing using "print" statement. e.g. struct X{ A:uint; B:string; C:bool; D:uint; ... }; // Take instance of this struct y : x; print y;
    Originally posted in cdnusers.org by vlsi_dude
    You can also use the built in print command in conjunction with "message" which makes it more efficient.
    This way the verbosity settings will also affect the printing.
    For example :
    messagef(LOW,"new packet just added \n") { print new_packet };
    Yaron
    Originally posted in cdnusers.org by thinkverification
