  2. Functional Verification
  3. Constraint issue
  • Subscribers 66
  • Views 15803
Constraint issue
archive over 18 years ago
I’m trying to constraint two fields through a keep statement, but I’m receiving an error. This is the code:
struct packet{
    clkm: uint;
    keep soft clkm == 100;
    pkt_delay: uint;
    keep soft pkt_delay * 2 * clkm
The error message:
      Previous constraints reduced its range of possible values,
        then the following constraint contradicted these values:
          keep pkt_delay * 2 * clkm
        Reduced: packet_s-@20.(pkt_delay*2*clkm) from [0..9999] into []
          Using: packet_s-@20.pkt_delay == [2116432017]
          Using: packet_s-@20.clkm == [100]
It seems that the last keep is ignored when attributing value to fields clkm and pkt_delay; I tried without the “soft” in the keep statements but received the same error.
Thanks in advice
Montu
Originally posted in cdnusers.org by vbdc_montu
    My previous post is incorrect: when I use the code above I didn’t receive any errors, but the constraints seems to be ignored and a get values like 1270727026 for the pkt_delay field. I get the error above when I remove the soft constraints
    Thanks for any suggestion
    if you're using PGEN (rather than IntelliGen) please try this:
    keep soft pkt_delay == calc_pkt_delay();
    calc_pkt_delay(): uint is {
    gen result keeping {
    it < 10000 / (2 * clkm);
    Yaron
    Originally posted in cdnusers.org by thinkverification
    Hi Yaron, I’m using IntelliGen. But I tried:
    keep pkt_delay < 10000 / 10000 / (2 * clkm);
    , as you suggested inside your method and it worked (and I get surprised because I think I have tried this before and still get the error...).
    Anyway, it worked!
    Thank you!
    Great! Glad I could help.
