  2. Functional Verification
  3. Reload problem, when using irun
  • Subscribers 66
  • Views 14745
archive over 18 years ago
Hi all!
I have the following problem:
When i use irun to load the specman with ncsim, it is impossible to perform RELOAD command from the specman gui, as well as, RESTORE command is restoring snapshot where e-files are already loaded.
has somebody encountered this problem?
Thanks a lot!
Originally posted in cdnusers.org by dg
    This is a know limitation of the reload command and is fixed in SPMN 8.1, which was just released.
    If you want to use irun you will have to wait for IUS8.1 to be released (should be within the next week)
    -hannes
    Originally posted in cdnusers.org by hannes
