  2. Hardware/Software Co-Development, Verification…
  3. ncelab: *F,INTERR: INTERNAL ERROR while running ncsc_run...
  • Subscribers 49
  • Views 2557
ncelab: *F,INTERR: INTERNAL ERROR while running ncsc_run on a systemC & verilog design
Shailendra
Shailendra over 17 years ago
I have a design which have a verilog Top & hirrarchical systemC modules instantiated in it.
Now while running the elaboration for this deesign I am getting crash in NCELAB.
It is not giving any error & no stack dump is also generated.
I am using the following command where I am getting this crash
ncsc_run \
                  -access rwc \
                  -MESSAGES $VERBOSE \
                  -loadsc $ID_DATA_DIR/libncsc_model.so \
                  -TOP ncvlog_lib.testbench:module
Here I am loading the systemC modules thru dynamic library & TOP is a verilog Top module "testbench"
Please provide some options thru which I can debug this error.
I am using following version of NCSIM
TOOL: ncelab  06.11-s004
OPERATING SYSTEM: Linux 2.6.9-42.ELsmp #1 SMP Wed Jul 12 23:32:02 EDT 2006 x86_64
MESSAGE: xst_isprot - default
Shailendra
  • Mickey
    Mickey over 17 years ago
    Hi Shailendra,
     Can you provide more specifics as to when you get the error?  Are you running in gui mode?  Were you able to execute the code previously?  Can you share the code?  If yes please feel free to send it to my email (jrodrig@cadence.com).
    As an FYI, the version you are using is somewhat dated.  If you can send me your code and I can try to run it on the latest update to the 6.11 release.
    Best regards,
    Mickey
  • Shailendra
    Hi Mickey,
    I am not using GUI mode.
    I am simply running in cmd mode. The problem is I can't share code.
    The design have a Top level Verilog in which a systemC instance is instantiated with mutiple systemC instances in it.
    As I am using ncsc_run for compiling I am looking for some option or help thru which I can generate some stack trace & can look into the issue.
    Can you please suggest certain options which I can use to get some more error messages or some hit & trials.
    It will be a great help for me.
    Shailendra
  • Mickey
    Hi Shailendra,
    Thanks for the reply.
    Be aware that the message you are seeing is an "internal error".  This means the problem has something to do with a unforseen situation being encountered by the simulator code, which may or may not be something you can affect.  Cadence R&D has encountered and fixed a handful of situations that led to errors similar to what you are seeing.
    Since you are using an old version of the IUS simulator, my first suggestion would be to download and install either a more recent version of IUS (IUS81 or IUS82) or if you need to stay within the IUS611 stream download the most recent hotfix to IUS611, which is 06.11-s017.
    Let me know if you need any assistance with downloading and/or installing the hotfix.
    Best regards,
    Mickey
