  2. Hardware/Software Co-Development, Verification…
  3. Fixed property help
  • Subscribers 49
  • Views 15580
Fixed property help
croc4
croc4 over 17 years ago
 Need a push in the right direction, I have been perplexed by what I'm seeing.
I have a layout file that I'm attempting to update, a number of the parts have fixed properties tied to them. So to remove this I go to 'edit', 'properties', I then select the part that I wish to change,this pops up a dialog box and shows the 'fixe' property as 'true'. I then select the 'delete' button, press apply then ok.
 I then select the move or delete buttons, select the part that I just changed, and in the command line section I get a message that says this symbol has a fixed property?, but I just removed this? Is there a different way to get around this?
Croc4
  • oldmouldy
    oldmouldy over 17 years ago
    You don't specify which version you are using.
    For 16.2, left-click on the "unfix" "push pin" on the toolbar, Fix / Unfix are net to each other. Move the mouse to blank space in the canvas, right-click, "Unfix All" will be on the pop-up, left-click on that entry, and the righ-click>Done, or F6 to accept the changes.
  • croc4
     Thanks for the reply, I'm using ver. 15.7. I'll try your suggestions
    croc4
