  2. Hardware/Software Co-Development, Verification…
  3. C-to-Silicon Error (CTOS-13043)
  • Subscribers 50
  • Views 15187
Romen
Romen over 14 years ago
I'm using C-to-Silicon to generate a RTL model for a CAVLD module from a H.264/AVC video decoder. During the build step, at the end of the process, I'm obtaining this error:
Saving design 'cavld_core' to cavld_core/elaborated. Writing Post-Build SystemC Simulation Model:
write_sim -type systemc -suffix _post_build_sc -birthday -recursive -o ./model /designs/cavld_core/modules/cavld_core.
Writing Post-Build Verilog Simulation Model:
write_sim -type verilog -suffix _post_build -birthday -recursive -o ./model /designs/cavld_core/modules/cavld_core.
Writing Verification Wrapper:
write_wrapper -o ./model/cavld_core_ctos_wrapper.h /designs/cavld_core/modules/cavld_core.
ERROR (CTOS-13043): Internal error encountered while executing build:
Expression [op == callOp || op->isControl()] returned false in file bstValidator.cpp at line 1135.
0x90a8c92: _ZN9CallStack4initEv
0x90a8e43: _ZN9CallStackC1Ev
0x90b63ba: _ZN5Error6formatERPc
0x90b6917: _ZN5ErrorC1Ejz
Error in processing command build
It would be most appreciated if someone can help me with this issue.
Thanks in advance for your help.
Best Regards.
Romén.
  • rradhakr
    rradhakr over 14 years ago
     Hi Romen,
    Sorry that you are seeing a crash. We continuosly strive towards making the CtoS more robust and appreciate any help we can get from customers.
    You are probably predicted what I am going to ask next: Would it be possible for you to contact Cadence customer support so that someone can work with you?
    If that is not an option, here are some tips:
    - Does your design pass simulation? Do you have a good SystemC (or any other language) TB to verify your DUT (design under test)? You can catch a lot of coding errors during simulation. You would be surprised how many customers simply write the SystemC DUT, don't simulate at the SystemC level, generate RTL from CtoS and do full simulation at the RTL level... IMO, those people are missing the point. You want to do all functional verification at the SystemC (high-level) and re-use the high level TB to verify the generated RTL.
     - Run with 'build -verbose'. It will print debug messages as it parses your design. You might be able to figure out which line it is having a problem with.
     NOTE: Please post all your future TLM-D (CtoS) questions to:
     High Level Synthesis Forum
    /forums/90.aspx
    Regards
    Rajesh
