  2. Hardware/Software Co-Development, Verification…
  3. Is it possible for VHDL to use a verilog/systemverilog package...
  • Subscribers 49
  • Views 5914
Is it possible for VHDL to use a verilog/systemverilog package ?
Xinwei
Xinwei over 13 years ago
 Hi all,
 I want to know if I compile one systemverilog package in a library, then in vhdl side, can it access the element in this package ?
For example .
//file pkg.sv
package pkg;
const int a =10;
endpackage
// //file  tb.vhd
library pkg_lib;
use pkg_lib.pkg.all;
I compile it by
'irun -makelib pkg_lib pkg.sv -endlib'
'irun -reflib INCA_libs/pkg_lib tb.vhd '
I got the error complaining the package pkg cannot be found in the library.  I want to know whether it is impossible to access a systemverilog package from the VHDL code , or I missed something ?  Thanks a lot !
Best regards,
Xinwei
  • jasonbrewer101
    jasonbrewer101 over 13 years ago
    I'm using Incisive 12.10.006 and to date I haven't found any way to make this possible. I've just had to rewrite the packages in VHDL for the moment! Regards, Jason
  • StephenH
    StephenH over 13 years ago
    Hi Jason.
    This isn't currently possible, but I'm collecting requirements from users and am working on a solution. Please can you let me know the details of what you need to access from the VHDL package? Feel free to PM me or email to stephenh@cadence.com if you'd prefer not to discuss the details in public.
    Thanks!
  • Xinwei
    Hi Stephen and Jason,
    Thanks for your reply.
    By the way, I have another question related to the package access (Or It is not only for pkg, but for the common access).
    For example,
    I have a source file src.sv that has a line "import pkg1::*;".   The pkg1 is defined in the file pkg1.sv.  Then I compile it by the following way:
    irun -c pkg1.sv -makelib lib1 src.sv -endlib
    In this situation, pkg1 is invisible for src.sv that compiled into lib1.  I know how to workaround this problem. But I still want to ask do you do this on purpose or maybe you can improve this to make pkg1.sv visible to src.sv even if it is compiled into a library.
    Please correct me if I misunderstand anything.
    Thanks and best regards,
    Xinwei
