  2. Hardware/Software Co-Development, Verification…
  3. need solution for following error in cadence RTL synthesis...
  • Subscribers 49
  • Views 15603
need solution for following error in cadence RTL synthesis tool
aathi27
aathi27 over 13 years ago
reg [7:0]cb[3:0][3:0];
Error   : Verilog-2001 feature. [VLOGPT-3] [read_hdl]
        : Multiple dimensions in file './sad.v' on line 8, column 22.
        : The design must be read in with 'read_hdl -v2001'.
reg [7:0]rb[3:0][3:0];
        : Multiple dimensions in file './sad.v' on line 9, column 22.
reg [7:0]abs[3:0][3:0];
        : Multiple dimensions in file './sad.v' on line 10, column 23.
reg cx1[3:0][3:0];
        : Multiple dimensions in file './sad.v' on line 11, column 18.
  • StephenH
    StephenH over 13 years ago
    This forum is for the following products only: Virtual System Prototyping products only.
    The first error message gives a hint:  The design must be read in with 'read_hdl -v2001'.
