  2. High-Level Synthesis
  3. Genus Synthesis Timing Report does not make any sense
  • Subscribers 22
  • Views 21655
saw235
saw235 over 6 years ago
I don't understand how timings are calculated in genus. Below is the synthesis timing report of one of my design, it mentions that critical path is met with 0 slack but the calculation does not make any sense to me because the datapath is 567 ps and the capture time is at 350 ps. So how is it that the timing is met? Usually there are some kind of negative slack if the timing is not met.
There seems to be some ambiguity going on here when one flop is launched at rising edge and captured at the falling edge.
I am targeting 1 GHz, hence target clock period is constrained to 1000ps.
Generated by: Genus(TM) Synthesis Solution 17.20-p003_1
Generated on: Jan 03 2020 05:55:41 pm
Module: top
Operating conditions: TT_0P80V_0P00V_0P00V_0P00V_25C (balanced_tree)
Wireload mode: enclosed
Area mode: timing library
Path 1: MET (0 ps)
Group: l2clk
Startpoint: (R) lsu_stbuf/stbuf_fwdbyteen_lo_dc3ff_dout_reg[1]/CLK
Clock: (R) l2clk
Endpoint: (R) dec_decode_illegal_any_ff_clkhdr_clkhdr_en_ff_reg/D
Clock: (F) l2clk
Capture Launch
Clock Edge:+ 500 0
Src Latency:+ 0 0
Net Latency:+ 0 (I) 0 (I)
Arrival:= 500 0
Uncertainty:- 150
Required Time:= 350
Launch Clock:- 0
Data Path:- 567
Slack:= 0
