  2. High-Level Synthesis
  3. Why does Stratus HLS report this error?
  • Subscribers 24
  • Views 22601
idwwwoqq808
idwwwoqq808 over 6 years ago
I'm trying to implement a module that reads and writes a memory. The memory is instantiated in the top module and passed down to submodules.
It seems there are errors in the generated memory header file.
I'm using Stratus 19.1 on CentOS 7. I've tried synthesizing "Lab 3: Explicit Memorys" (which comes with Stratus) and it was completed without errors.
Can anyone tell me what the cause of this error and how to solve it?
Also, the way I instantiate memories is same as in Lab3.
I'd prefer to keep ports of memories the same because in the project I'm working on, one module only writes to a memory block and another module only reads from this memory. They will access the same memory simultaneously so I'd rather not to use a shared interface.
Here's the setting of the memory:
And Here's my code:
/* Test3.h */
#include "cynw_p2p.h"
#include "memlib.h"
#include "writer_wrap.h"
#include "reader_wrap.h"
SC_MODULE(Test3)
public:
sc_in < sc_uint<8> > din;
sc_out< sc_uint<8> > dout;
// Declaration of clock and reset parameters
sc_in_clk clk;
sc_in < bool > rst;
sc_signal< bool > sgn;
//sc_uint<8> mem[256];
RAM8x256::wrapper< CYN::TLM > *mem;
writer_wrapper m_writer;
reader_wrapper m_reader;
SC_CTOR(Test3)
: m_writer("writer"),
m_reader("reader"),
clk( "clk" ),
rst( "rst" )
m_writer.clk(clk);
m_writer.rst(rst);
m_writer.din(din);
m_writer.sgn(sgn);
m_reader.clk(clk);
m_reader.rst(rst);
m_reader.dout(dout);
m_reader.sgn(sgn);
mem = new RAM8x256::wrapper< CYN::TLM > ("mem");
m_writer.m_mem(*mem);
m_reader.m_mem(*mem);
mem->clk_rst(clk,rst);
/* writer.h */
#include "memlib.h"
SC_MODULE(writer)
public:
sc_out< bool > sgn;
sc_in_clk clk;
sc_in < bool > rst;
//sc_uint<8> *m_mem;
RAM8x256::port_1< CYN::TLM > m_mem;
sc_uint<8> ad;
//SC_HAS_PROCESS(writer);
//writer(sc_module_name &name,
// sc_uint<8> mem[256])
// :m_mem(mem)
SC_CTOR(writer)
SC_CTHREAD(writer_thread, clk.pos());
async_reset_signal_is(rst,0);
//HLS_MAP_TO_MEMORY(m_mem,"RAM8x256");
void writer_thread();
/* writer.cpp */
#include "writer.h"
// The thread function for the design
void writer::writer_thread()
// Reset the interfaces
CYN_PROTOCOL("writer_thread");
sgn.write(0);
ad=0;
//m_mem.reset();
wait();
// Main execution loop
while (1)
m_mem[ad]=din.read();
sgn.write(din.read()[7]);
ad++;
wait();
/* reader.h */
#include "memlib.h"
SC_MODULE(reader)
public:
sc_in < bool > sgn;
sc_in_clk clk;
sc_in < bool > rst;
sc_uint<8> ad;
sc_uint<8> out_tmp;
//sc_uint<8> (&m_mem)[256];
RAM8x256::port_2< CYN::TLM > m_mem;
//SC_HAS_PROCESS(reader);
//reader(sc_module_name &name,
// sc_uint<8> (&mem)[256])
// :m_mem(mem)
SC_CTOR(reader)
SC_CTHREAD(reader_thread, clk.pos());
void reader_thread();
/* reader.cpp */
#include "reader.h"
void reader::reader_thread()
CYN_PROTOCOL("reader_thread");
ad=0;
//m_mem.reset();
wait();
while (1)
out_tmp=m_mem[ad];
if(sgn.read()){
dout.write( (~out_tmp)+1 );
}else{
dout.write(out_tmp);
wait();
ad++;
wait();
The "Job Trace" reports:
00148: Normalization and optimization:
NOTE 00860: Long int data types are being implemented with 64 bits.
02923: Dissolving function boundaries.
02924: Dissolved 198 function calls.
ERROR 03144:# at memlib/c_parts/RAM8x256.h line 3175 #
ERROR 03144.# Call to unresolved virtual function or function called via #
ERROR 03144.# pointer #
FATAL 02368:# at writer.h line 8 #
FATAL 02368.# Not all sc_port->sc_interface bindings and virtual function #
FATAL 02368.# calls could be resolved #
01445: Summary of messages of severity WARNING or greater:
01193: SEVERITY MSGID CNT
01198: FATAL 02368 1
01198: ERROR 03144 1
stratus_hls failed with 2 errors and 0 warnings.
  • jimmashyeg
    jimmashyeg over 5 years ago
    I'm trying to implement a module that reads and writes a memory. The memory is instantiated in the top module and The tutorial, instead, will not explore the capabilities of the HLS tool for design-​space exploration. ... accelerator name [dummy]: mac * Select design flow (​Stratus HLS, ... configured by the accelerator initialization script is reported below​. ... jouets et figurines à https://figurinestore.fr/ In case of simulation errors during the RTL simulation that do not ......
  • Rosemary
    Rosemary over 5 years ago
    According to 3m n95 buyers, In this guide and in the comparing prebuilt material we incorporate a gas pedal that performs duplicate and collect (MAC) on number vectors of configurable length. In particular, we carry out the accompanying little portion of calculation.
