  2. Logic Design
  3. RC gated clock - automatic insertion
  • Subscribers 62
  • Views 2851
guyra
guyra over 18 years ago
During the synthesis, the RC added gated clock on several gates, thus changed the attribute of the gate to " break_timing_paths = true".
I don't understand the reason for that, since I dont think there is a gated clock on this cell.
How can I debug this issue?
Is there a way to find out why the RC think this is a gated clock.
I tried to use the fanin command on this gate pins (all pins) and to check if one of the start point is gated clock, but I didn't find any thing..
Thx
  • grasshopper
    grasshopper over 18 years ago
     Hi Guyra,
     this is usually do to clock_gating_checks. Most combo cells infer a clock gating check if a signal defined as clock drives one of the pins. This is not just RC but most tools out there behave that way. As a result of the clock_gating_check, the path needs to be segemented hence what you are seeing or sounds like it. If the questions is what gates infer clock gating checks and which do not, I am not sure but I belive things like muxes do not infer them. Be careful since a clock_gating_check violation is likely a real violation unless their is design knowledge not captured in the SDC constraints.
    good luck,
    gh-
