  2. Logic Design
  3. constant propagation in RC
  • Subscribers 62
  • Views 14546
designer
designer over 18 years ago
Hi all,
In some sub-modules there are some output ports which are assigned to a constant (e.g. assign OutPort1 = 1'b0 ). I expected that RC propagates these constants and removes the output ports from the sub-module interface. This should also be the case for the destination sub-module which receives this signal. For example in the following code I assume after synthesis RC removes the op1 and ip1 ports since they are constants:
sub1    i_sub1 (
                      .op1 (op),  // output op1 is assigned to zero in the sub1
                       .opX(X),
sub2    i_sub2 (
                      .ip1 (op),
                       .ipX(X),
 Any idea why this does not happen?
Thank you for comments in advance!
Masoud
