  2. Logic Design
  3. how to compare designware like DW02_multp with LEC
  • Subscribers 64
  • Views 17192
codefire
codefire over 18 years ago
hi everyone,
Our design instantced a lot designware and we always compare these designware with their behavior model when run FV with LEC. This method always works, only except DW02_multp and some other designware. So, we'll blackbox these designware to pass the FV. But as DC do a lot of optimization to DW02_multp's input and output pins, while we must set constraints accordingly. These constraints lead to so many troubles to us as our design changes or re-synthesize. I was wondering if there is any way we also can compare DW02_multp without any blackboxes set. Thanks!
  • Ryan Z
    Ryan Z over 13 years ago
    it's like 5 years and does LEC have a solution for that now?
  • David L
    David L over 13 years ago
    There is a solution article that you can check out...
     Titled "How to avoid false NEQs while comparing Synopsys DesignWare DW02_mult_n_stage and DW_*_pipe?"
    (or with this URL below)
    http://support.cadence.com/wps/myportal/cos/COSHome/viewsolution/!ut/p/c5/dY1bcoIwAEXX4goSgpDwCUEejdIJjTzyk6GiCJZQKLWDqxcX0HM_z9w5QIJ1urq3TTW3g66-QAGkrQwUUoNtofNOEwJjYicszXZwBeSvh63gP7gQlEDil0fIINAJA-HBmLL4jWATQWaDTA9Tv5YEKKLT5PnDofFdn4tlzNBcKhRGMspJKz4o27edwng_LduDtHqBLrLuGpOan3cqFqtC1lwvkre5yVL6N6ZTeb3VO_1zvhz51QkipZwHLk64g-gXek2YZlwux6QoPOWPuuMbkERDfwbfN_0IiLt5AjZXum4!/dl3/d3/L2dBISEvZ0FBIS9nQSEh/
  • conformalfan
    conformalfan over 13 years ago
    You need special treatment to verify some DW modules.  You must use the ANALYZE MODULE command when verifying DW02_multp to avoid getting false noneq
     analyze module *DW02_multp* -partial_sum_outputs -golden -replace
