  2. Logic Design
  3. Problem with ORCAD Capture Simulation
  • Subscribers 62
  • Views 6657
scdr
scdr over 18 years ago
 Version of ORCAD is 16.
I try to realize example from Tools\Capture\Tutorial\CAPTUTOR.EXE.
"Processing Your Design" .
Project name is DCLOCK.obj
When I run Tools/Board Simulation
This message appear.
Error: Failed to invoke "ncvhdl -cdslib C:\Orcad Projects\Indesign\cds.lib -hdlvar C:\Orcad Projects\Indesign\hdl.var -Append_log -logfile C:\Orcad Projects\Indesign\Detail.log -message -v93 C:\Orcad Projects\Indesign\stubI.vhd" as a child process.
::Не удается найти указанный файл.
Process cancelled by user or Errors/Warnings encountered.
Such error with my own model of multiplexer.
How can I simulate  with no errors?
  • tpylant
    tpylant over 18 years ago
    I’m guessing that you don’t have a license for ncvhdl or that a path is incorrectly set. However, you would probably get a better answer from the Orcad users on the PCB forum.
    Tim
  • scdr
     Thank You, Tim (tpylant).
  • Amritapuri
    Amritapuri over 17 years ago
    For the lite version of OrCAD, mostly it's the case with incorrect path setting.
