  2. Logic Design
  3. LEC : Asynchronous Reset Issue
  • Subscribers 63
  • Views 15349
automotive
automotive over 18 years ago
In RTL (G)  to post layout netlist (R)  LEC, we are seeing that the asynchronous reset logic is getting removed from the revised side for LEC. We tried with/without the sequential redundant option. The results remain the same.
  • Jaydip Mehta
    Jaydip Mehta over 18 years ago
    Looks like an synthesis issue rather than LEC. Do you have reset logic preset in synthesized netlist (Revised)? Also you can check weather anything is been done with reset pin in your LEC do file.
