  2. Logic Design
  3. How to save global constrain settings In Allegro?
  • Subscribers 62
  • Views 15456
Raam
Raam over 17 years ago
In Allegro performance How to save global constrain settings from one PC to another
  • oldmouldy
    oldmouldy over 17 years ago
    Probably better to post this kind of question in the PCB Forum.
    On the machine that has the constraints defined, In Constraint manager, File>Export, Constraints or Technology file, OR In PCB Editor, File>Export>Techfile. Take the resulting file to the "other" machine(s) and use File>Import in the appropriate place, to get the settings imported.
    For an existing board, the constratints will "travel" in the BRD data so there is no need to take any action if the BRD data is being moved.
  • Raam
    thank u
    Raam
    Ishare
