  2. Logic Design
  3. RTL Compiler: is there a timing path between 2 FF?
  • Subscribers 63
  • Views 15645
magic
magic over 17 years ago
I'm interested to know if there is an arc between 2 FF without using report timing (time consuming)
I have the from and to points and just need to know if there is a path between them.
thanks.
  • johannes
    johannes over 17 years ago
    Hi magic,
    I think, something like this should work:
    foreach start [fanin -start YOUR-END-POINT] {[if {YOUR-START-POINT eq $start} {puts "Path exists"}]}
    YOUR-START-POINT has to be in RC-style, i.e. /designs/top/insta... (or you put a "[find /designs -pin YOUR-START-POINT]" instead)
    Hope this helps.
    Johannes
  • jflieder
    jflieder over 17 years ago
    I believe you will need to use fanin –struct as the standard –fanin command is timing path based (I think).
    -Jeff-
  • magic
     thanks guys ! I'll try it soon.
