  2. Logic Design
  3. Cadence 6.1.3 libraries
  • Subscribers 61
  • Views 11352
StreamCX
StreamCX over 17 years ago
I try to import ncvhdl but next error appeared in vhdlin.summary
And this is screen
/* [URL=http://img519.imageshack.us/my.php?image=screenshotz.png][IMG]img519.imageshack.us/.../URL] */
 TOOL:    ncvhdl    06.11-s016: Started on Mar 03, 2009 at 09:42:50 NOVT
ncvhdl
    -NOCOPYRIGHT
    -messages
    -smartorder
    -LOGFILE /tmp/vhdlin_anal.a2495
    -WORK cds.lib
    -ERROR 10
    -CDSLIB /tmp/ncvhdl_cdsliba2495
    /cds/ic61/tools.lnx86/dfII/samples/vhdlin/Test1//or_gate.a.vhd
ncvhdl_p: *F,WRKBAD: logical library name WORK is bound to a bad library name 'cds.lib'.
TOOL:    ncvhdl    06.11-s016: Exiting on Mar 03, 2009 at 09:42:50 NOVT  (total: 00:00:00)
WARNING (VHDLIN-226):
How can I solve this problem?
  • Mickey
    Mickey over 17 years ago
    the file indicated in the -CDSLIB argument (/tmp/ncvhdl_cdsliba249) should have logical and physical path definitions.  eg...
     define mywork  ./some/path/to/mywork
     define otherlib  ./some/path/to/otherlib
    when doing your compile with ncvhdl, you can specify into which library the objects get compiled with the -WORK command line option.  The valid argument to -WORK is a logical library name that is defined in the CDSLIB referenced file.  So in the example provided above the valid arguments could be either mywork or otherlib.
    Hope that helps.
    Mickey
  • StreamCX
     Mickey
    Thank You.
    But I solve this problem by replacing cds.lib in work directory.
    This trouble was with my cds.lib.
    I can not check your solution beacuse i am not in university now, where Cadence installed.
    But another question.
    How can I add all Cadence libraries to a library manager?
    archive over 17 years ago
    to include all Cadence libraries in your session you can include the cds.lib in
    <path to IC installation directory>/share/cdssetup/dfII/cds.lib
