  2. Logic Design
  3. Path _Delay Command
  • Subscribers 63
  • Views 1514
Path _Delay Command
Kliatakis
Kliatakis over 17 years ago
Hello!
I am a new user of RTL Compiler and i am trying to synthesize a combinational circuit(with inputs A,B and an output named Output) in order to get later a layout from SoC Encounter and i want to constraint its delay. I saw in RTL compiler's manual the command
path_delay -delay integer
     { {-from {instance |external_delay |clock |port |pin }...
       |-through {instance |port |pin }...[-through...]...
       |-to {instance |external_delay |clock |port |pin }...}...
       |-paths string }
     [-lenient] [-mode mode_name ] [-name string ]
 in RC i put the command like this:  path_delay -from {A} -to {Output} -delay 4000 but this does not seem to be correct.I would appreciate any help!Thanks in advance!
  • johannes
    johannes over 17 years ago
    Hi!
    In general, this is correct, as long as an input port "A" and an output port "Output" exist in your design. What error do you get?
    Nevertheless, I would recommend to use the following style:
    path_delay -from [find /designs -port A] -to [find /designs -port Output] -delay 4000
    Johannes
  • Kliatakis
    I managed to get it to work properly!but thanks !
