  2. Logic Design
  3. How to increase timing table dimensions in a lib file created...
  • Subscribers 63
  • Views 14930
How to increase timing table dimensions in a lib file created from do_extract_model
vavendan
vavendan over 17 years ago
Hi
I generated a lib file with the command do_extract_model but the timing table dimension have only 2 dimensions. I need to increase the timing table in all range of the input slew clock, I mean , I need to generate timing tables with dimension 5x5. I used the switches -input_slews {input_slew1 input_slew2 ... input_slew5}, -clock_slews {clock_slew1 clock_slew2 ... clock_slew5 and output loads {load1 load2 ... load5}
But the timing tables keep the same dimension.
Please Could you help to solve this issue?
  • johannes
    johannes over 17 years ago
    Please forget about this post ... I've just realized, that you are talking about BuildGates, so you are in the correct forum ...
    Sorry! Unortunately, I have no answer for you ...
    Please send this question to the Digital Implementation forum.
    Johannes
