  2. Logic Design
  3. Power nets vs offpage connector
  • Subscribers 62
  • Views 15961
Jamez
Jamez over 17 years ago
How can I get a Power net called V5P and an offpage conn. Called V5P to be the same net? Capture seems to create 1 net called V5P and another called V5P_######## (random number).
Jim
  • oldmouldy
    oldmouldy over 17 years ago
    Capture creates two net names because they are not the same net.
    You need to be aware of the hierarchy of naming net objects, Hierarchical Port overrides Off Page Connector overrides Global Power Symbol overrides Net Name overrides un-named net. IF you connect a net connected to a global power symbol to an off page connector, the off page connector takes over the naming of the net AND the off page connector MUST be used to define the connectivity in the design, otherwise you will get two net names.
