  2. Logic Design
  3. UPF to CPF conversion
  • Replies 14
  • Subscribers 67
  • Views 32193
vicky
vicky over 17 years ago
Is there any utility which would do a conversion of an UPF file to CPF file. I have a testcase which has been implemented using UPF and now I am planning to implement the same using CPF. I did a manual conversion of the commands to create the power domains  but I feel that the way the switch cells and isloation cells are defined in the CPF and UPF is very difficult to convert from it.
  • Mickey
    Mickey over 15 years ago
    Hi Betty, PIA is now integrated directly into the CLP user interface. When in the CLP gui (lec -lp –verify –gui) in the upper left pane, expand the Design Setup section and click on Power Spec. This is where you can enter the appropriate power intent content. Best regards, Mickey
  • bbai
    bbai over 15 years ago
    Hi, Mickey:
    So right now this is no direct UPF-CPF conversion, such as a script running automatically convert UPF to CFF, but rather
    Input specs into the GUI upon the UPF to create a CPF file. Am I right?
    Thanks again,
    Betty
  • Mickey
    Sorry Betty I misunderstood your questions.  to read in a UPF and convert it to a CPF you will need to read it in and write out the corresponding *.cpf by adding instructions to do so in the *.do file that you pass to CLP.  The script would be something like the following:
     CLP.do script
    set lowpower option -netlist_style logical
    read library -liberty path/to/design.lib
    read design <hdl_files>
    read power intent -upf path/to/my.upf
    write power intent -cpf path/to/my.cpf
    Btw, the *.lib is required because the UPF related power intent information is included in the *.lib in addition to the *.upf.
    Let me know if that helps
    Best regards,
    Mickey
  • pavannelluri
    pavannelluri over 9 years ago
    Can't we directly use UPF file  for low power simulations ? if so, what are the ncelab options ? i am not using irun, some people use -lps_1801, what is this option
    thanks in advance
    Pavan
