  2. Logic Design
  3. UPF to CPF conversion
  • Replies 14
  • Subscribers 68
  • Views 32815
vicky
vicky over 17 years ago
Is there any utility which would do a conversion of an UPF file to CPF file. I have a testcase which has been implemented using UPF and now I am planning to implement the same using CPF. I did a manual conversion of the commands to create the power domains  but I feel that the way the switch cells and isloation cells are defined in the CPF and UPF is very difficult to convert from it.
  • Mickey
    Mickey over 17 years ago
    Hi Vicky,
    We have a conversion utility that currently requires a beta software license agreement to use.  Let's take this offline and I can help with getting the license and using the utility.  Feel free to email me at jrodrig@cadence.com.
    Best regards,
    Mickey
  • ramyavt
    ramyavt over 16 years ago
    I am a graduate student in need of a UPF to CPF utility for academic related activities. Kindly let me know the possiblity of obtaining the utility from you
    Ramya
  • Mickey
    Mickey over 16 years ago
    Hi Ramya,
    The ability to convert upf to cpf and vice versa is included as part of the Conformal Low Power license and tool. If you have a conformal low power tool you would invoke clp as follows: unix> lec -lp -verify
    Then you can either use the interactive mode to convert: setup> upf2cpf <upf_filename>
    or you can use the gui: setup> set upf on
                                              setup> start pia
    then within PIA use the File -> Import from UPF option to choose the UPF to be converted.
    Please feel free to email me offline, jrodrig@cadence.com if you have any questions.
    Best regards,
    Mickey
  • ramyavt
     Hi Mickey,
    Thanks for your information and quick reply. The information is of great importance to my work.
    Thanks a lot!!
    Ramya
  • knox9510
    knox9510 over 15 years ago
    Greeting. Mickey
    Recently released CLP version has only beta version of document written about PIA.
    tool is not supporting "start pia" anymore.
     If toy are still using CLP, please let me know what to do for open cpf generation gui.
     with regards.
  • Mickey
    Mickey over 15 years ago
    Hi. PIA is now integrated directly into the CLP user interface. When in the CLP gui (lec -lp –verify –gui) in the upper left pane, expand the Design Setup section and click on Power Spec. This is where you can enter the appropriate power intent content. Best regards, Mickey
  • allcards
    allcards over 15 years ago
    Hi Mickey, I had a similar enquiry as Ramya, thanks for the helpful answer!
  • jaizone
    jaizone over 15 years ago
    I am not sure if this utility is present. I would like to have one that can convert from the CPF format to UPF to be used with dynamic power simulations Regards
  • jaizone
    oops i did find that the write_power_intent accomplishes this task though.
  • bbai
    bbai over 15 years ago
    HI, Mickey:
    I encountered your reply when I was searching for UPF-CPF conversion.
    I have the lec, I can start it as you directed, however I can;t load up PIA,
    DId tool interface changed after years? any updates?
    thank you very much for the help,
    Betty
