  2. Logic Design
  3. error occured while importing netlist
  • Subscribers 64
  • Views 16142
gopinathkannan
gopinathkannan over 16 years ago
the following error occured which is,
ERROR(302) Device library error detected
for eg,
Pin 'HBPRI#' for function 'TYPE8' on device '945GMS' has swap/pinuse inconsistency.
  • grasshopper
    grasshopper over 16 years ago
    Hi gopinathkanna,
    would you be so kind as to provide some context ? Like which tool you are running and what the question is.
    I believe your question is implementation related but cannot tell based on your information
    thanks,
    gh-
  • gopinathkannan
     hi i am using ALLEGRO 14.2 while importing netlist error 302 is occured and particular library cannot be transfered to allegro like that the error is indicated if it possible for you to clear the error please give ur guidelines to clear that error.
    for eg,
    ERROR(302) Device library error detected.
    Pin 'HBPRI#' for function 'TYPE8' on device 'U3' has swap/pinuse inconsistency.
  • grasshopper
    If this is an Allegro question, please post to the SPB packaging community. The logic design forum handles mostly questions regarding synthesis, formal verfication and DFT
    regards,
    gh-
  • ryangarg05
    ryangarg05 over 16 years ago
     Well, got the same problem, but everything was fine now..just hope that you'll soon be able to solve it too..
