  2. Logic Design
  3. Constraint two path in the design to have equal propagation...
  • Subscribers 64
  • Views 16412
Constraint two path in the design to have equal propagation delay
diablo
diablo over 16 years ago
Hi all,
How to contraint two path in the design to have equal propagation delay using SDC file in RTL compiler? For example, is there a way to specify in RTL compiler to make path point A to point B  have equal propagation delay as path point A to point C in the design?
Thanks for your time.
Regards.
  • grasshopper
    grasshopper over 16 years ago
     Hi diablo,
     The SDC command set_data_check is the the constraint that you are looking for. Unfortunately, it is not supported in RC today so you will have to resort to alternative workaround such as using set_max_delay/path_delay
    hope this helps,
    gh-
  • diablo
    Thanks gh. I will try using path_delay.
  • Genky
    Genky over 16 years ago
    Is this command(set_data_check) still not supportted?
    Genky
