  2. Logic Design
  3. how to prevent the use of specific library cells for some...
  • Subscribers 63
  • Views 16646
how to prevent the use of specific library cells for some instance in the design?
diablo
diablo over 16 years ago
I tried
set_attribute_avoid true {TLAT*} top_design/inst1
but this prevent this cell to be used from entire design instead of just inst1.
Thanks for your time.
Regards.
  • grasshopper
    grasshopper over 16 years ago
     The same technology used for top-down MSV called libray domains, enables this. Library domains are a simple yet incredibly powerful concept in RC. Basically you would do something like
    create_library_domain withLat
    create_library_domain withoutLat
    set_attr library_domain {my_lib} [find / -library_domain withLat]
    set_attr library_domain {my_lib} [find / -library_domain withoutLat]
    set_attr avoid true [find [find / -library_domain withoutLat] -libcell LAT*]
    set_attr default true [find / -library_domain withLat]
    set_attr libray_domain withoutLat <blocks with latch avoided>
    An interesting blog discussing the use of the same technology for accurate power modelling can be found at
     http://www.cadence.com/community/blogs/ld/archive/2009/03/31/dont-let-power-kill-your-project.aspx
    good luck,
    gh-
  • diablo
     Thanks gh for your suggestion and sharing the interesting blog about library domain. I appreciate your help.
  • sudhirjain
    sudhirjain over 16 years ago
    Gh, Is similar possible in SOC Encounter as well?
    I want to restrict some instances for be optimized with one set of libs and rest of the instances with all the libs.
    thanks and regards
    Sudhir
  • dacyace24
    dacyace24 over 16 years ago
     Got the same problem..thanks for answering and sharing what you know grasshopper, this is a good source of information, just lucky to read some ideas here..
