  2. Logic Design
  3. Check for positional parameter assignments?
  • Subscribers 64
  • Views 15320
JNearing
JNearing over 16 years ago
I am looking for a method to detect occurrences of positional parameter assignments. I don't want the IP integration to use positional parameter assignments since changes to the underlying IP could render the parameter assignments obsolete/incorrect. Does anyone know of a tool that will report the occurrence of positional parameter assignments? I want to locate all occurrences so that I can request changes/fixes. I was thinking that perhaps Conformal would report it, but I can't find any rules related to positional parameter assignments.
  • grasshopper
    grasshopper over 16 years ago
    Hi JNearing,
    both syntaxes are perfectly legal so there is no reason why the tools would distinguish one from the other. I am not aware of any linting tools that makes any distinction between the two in terms of log messages, etc. but maybe on of them does. Another alternative is to take advantage of the Perl based verilog parser and add the hooks for what you need. I am not sure how elaborate your design and environment is but I think fully automating the task may be more work than it is worth. I know RTL Compiler provides hooks to easily identify parametrized blocks and I believe Conformal LEC may do that too. I would then use either of these tools to extract a list of all parametrized blocks and then review those through a combination of manual labor and rudimentary scripting (read grep, TCL, Perl, etc.) I would imagine that approach, while not fully automated, will get you to the bottom of things in a reasonably short amount of time
    good luck,
    gh-
  • mkapil
    mkapil over 16 years ago
    If you run HAL on the design, it will issue a check PRMNAM, which flags occurence of positional parameter assignment.
    -Kapil
  • croy
    croy over 16 years ago
    Hi
    In Conformal it's linting message HRC3.8. Default severity is Warning.
    Chrystian
