  2. Logic Design
  3. Simulation of file .JED
  • Subscribers 63
  • Views 15814
adios
adios over 16 years ago
 Hello, I want simulate a file .JED in ORCAD, Could somebody explain me?
I am using PAL20L8B and I have the .JED file.
Thanks.
  • oldmouldy
    oldmouldy over 16 years ago
    There used to be a product called Express which was used for PLD simulation but this was EOL at December 2000. If you have a version of OrCAD that is that old you would have to rely on the documentation such as it might be since I doubt that many folks can still remember how to drive tool. Now you would be looking at a VHDL netlist and VHDL simulator - you might want to look at the FPGA vendor websites and see if they have a suitable solution, the Cadence VHDL simulators run on UNIX and looking to solve much more complex digital simulation problems than a 20x8 PLD.
  • adios
     I have Orcad 16.2 and I am using the dig_pal's library, this schematic has an option to put  file *.JED but when I am going to simulate the program, it said that unable to open the file so I put in the 'include file' but the program doesn't recognise the file, all the lines are errors.
    The problem is the same with all device.
     Thank you.
