  2. Logic Design
  3. LEC between a posedge DFF and a low-pass D latch followed...
  • Subscribers 63
  • Views 16089
LEC between a posedge DFF and a low-pass D latch followed by a posedge D flop
WorldMaker
WorldMaker over 16 years ago
Hi all,
There are two flops which should be equivalent, but Conformal reported an unmapped latch and a non-equivalent DFF. The 1st flop is a posedge D flop described by "always @(posedge CLK)" statement, and the 2nd flop is comprised of a low-pass D latch which is followed by a posedge D flop and the clock of the latch and flop is shorted.
My question is: How to remove the unmapped latch and fix the non-equivalent DFF? Should I delete the compared DFF using command "delete compared points DFF_reg" ?  The verilog of the two flops and the dofile are shown as follows:
////////////////verilog of the1st flop (DFF_a.v)///////////////
module dff (CLK,D,Q);
input  CLK;
input  D;
output Q;
reg    Q;
  Q <= D;
endmodule
////////////////verilog of the 2nd flop (DFF_b.v) ///////////////
input  CLK;
input  D;
output Q;
reg    Q;
reg    LAT;
always @(CLK or D) begin
if (~CLK) LAT <= D;
end
always @(posedge CLK) begin
Q <= LAT;
end
endmodule
 /////////////////////dofile//////////////////
read design DFFa.v -gol
read design DFFb.v -rev
go
If the 1st flop is changed to the combination of a low-pass and high-pass d latch and the 2nd flop is unchanged. In this case, both of the two flops has two primary output pins: LAT, Q.
Similarly, there are also unmapped and non-equivalent points, and how to verify the two flops? Verilog files of the two flops are as belows:
//////////////////verilog of the 2nd flop (DFF_c.v) ////////////////
module dff (CLK,D,Q,LAT);
input  CLK;
input  D;
output Q;
output LAT;
reg    Q;
reg LAT;
if (~CLK)  LAT <= D;
if (CLK) Q <=LAT;
end
endmodule
////////////////verilog of the 2nd flop (DFF_d.v) ///////////////
input  CLK;
input  D;
output Q;
output LAT;
reg    Q;
reg    LAT;
if (~CLK) LAT <= D;
end
Q <= LAT;
end
endmodule
Justin
  • WorldMaker
    The problem has been fixed with the following remodel commands:
    remodel -unfold_dff  .....
    remodel -red_dlat ....
    Justin
