  2. Logic Design
  3. Complier error
  • Subscribers 63
  • Views 14837
Complier error
jahanzebanwer
jahanzebanwer over 16 years ago
Dear All.
I am trying to run somebody's code (in VerilogA) on Cadence and test it using Virtuoso. Actually the cell name noisymos calls for a function (another cell) which is in the same library. The second function name is wire. When i run the code. the compiler says that it cannot open the cellview called 'wire' in 'r' mode whereas the cell wire is placed in the same library and has all the persmissions of read, write and execute. Can anyone suggest me the possible reason fo this error ?
Thank you for your time.
jahanzeb
  • tpylant
    tpylant over 16 years ago
    I am much more familiar with Verilog than Verilog-A, but could the problem be caused by using a reserved keyword (‘wire’) as a cellname? I know in Verilog that would be illegal.
    Tim
