  2. Logic Design
  3. Problem with Simvision hanging in an endless loop
  • Subscribers 64
  • Views 28743
Rony Ross
Rony Ross over 16 years ago
I have a problem with Simvision hanging in an endless loop. I encounter this problem from time to time probably since I use a lot of complicated always @(*) blocks. The problem occurs with two blocks that have some dependencies between them. However, it is not a combinatorial loop. I believe that it got something to do with the way that Simvision creates and updates its dependency tree. Usually, some "cosmetic" change, such as taking out a line and changing it to "assign ...", solves the problem. However, it is very difficult to find out which line causes the problem. I tried to reproduce a simple example below. I belive that it can be even simpler.
module endlessloop
 output reg c_cld
  parameter CREATE_ENDLESS_LOOP = 1; // =0 will not cause the endless loop
reg a;
reg b;
reg c;
reg d;
reg d_cld;
reg clk;
reg rst_l;
initial
begin
  clk = 1'b1;
  rst_l = 1'b0;
  #50 rst_l = 1'b1;
end
always
  #10 clk = ~clk;
always @(posedge clk or negedge rst_l)
begin
  if (~rst_l)
  begin
    c_cld <= 1'b0;
    d_cld <= 1'b0;
  end
  else
  begin
    c_cld <= c;
    d_cld <= ~d_cld;
  end
end
always @(*)
begin
  $display("%d; in 1",$time);
  if (CREATE_ENDLESS_LOOP)
  begin
    a = 1'b0;
    d = 1'b0;
  end
  a = b;
  d = d_cld;
end
always @(*)
begin
  $display("%d; in 2",$time);
  begin
    c = 1'b0;
    b = 1'b0;
  end
  c = a;
  b = d;
end
endmodule // endlessloop
  • TAM1
    TAM1 over 16 years ago
    The simulator is behaving correctly in this. Your block 'one' has some events which trigger block 'two', which has some events which trigger block 'one' and so on, ad infinitum. To avoid this kind of behavior, many design methodologies don't allow combinatorial blocks to feed back to each other, even if the signals involved are apparently unrelated. Because every signal in a block can be updated when it executes, even if triggered by an event on another signal entirely, you need to be aware that a combinatorial feedback path can be triggered even when you think it would not.
    You can work around this using the command line option "-delay_trigger" on your ncvlog command line. It will wait until the last assignment on a net before determining if the net had an "event" on it.
    PS. I found this information looking a Cadence solution published at: http://support.cadence.com/wps/mypoc/cos?uri=deeplinkmin:ViewSolution;solutionNumber=11594558
  • Rony Ross
    Thank you for the reply.
    Unfortunately, I don't have access for the link of the Cadence solution. For some reason I couldn't find this flag in my Cadence help. However, it solves the problem with the example that I gave. Now it raises few more questions...
        1. What else does this flag do? Would it have any other effect on my simulation?
        2. Why is it an ncvlog flag and not an ncsim?
        3. Although it is a correct behavior, one could expect the following:
            1. A Lint warning
            2. That the simulator won't hang. It should exit with a warning that it encountered an infinite loop involving the following blocks …
  • Shalom B
    Shalom B over 16 years ago
    Here is the content of that note:
     Using the -delay_trigger switch to avoid repeated retriggering of always blocks due to glitches
    Problem
    Sometimes there are situations where glitches on signals result in repeated re-triggering of the blocks which reference them.
    A Verilog always block executes when an object in the event control expression for the block has changed value from when the block was last executed. This default wait mechanism is sensitive to zero-width glitches on the variables the block is waiting on. These glitches are usually created when a writer process assigns a default value to the variable and then overwrites it with a different value. Even if the writer changes the variable back to the old value, there was a change in the value of the variable before it was changed back to the old value, and that is sufficient to wake up the waiting block. When such glitches are combined with a combinational loop in the design, they can stall the simulation.
    Consider the following example:
    module top();
    reg a,b;
    initial begin
      #1 b = 1;
      #1
      $finish;
    end
    always @(*) begin : BLK_B_TO_A
      $display("Entering first block");
      a = b;
      a = 1'b0;
    end
    always @(*) begin : BLK_A_TO_B
      $display("Entering second block");
      b = a;
      b = 1'b1;
    end
    endmodule
    If you run this example code with the -linedebug switch:
    % irun -linedebug test.v
    You will see a hang with both the blocks triggering each other continuously. How can one avoid
    Careful observation shows that they trigger each other because of glitches.
    How can one avoid this?
    Solution
    The sequence of events happening in the above example is as follows:
    - The first update to 'b' is made at 1 NS from the initial block.
    - This causes the first always block to trigger and both the updates to 'a' are made. Finally 'a' gets the value 0.
    - Update to 'a' causes second always block to trigger. First update to 'b' is the value 0 and the second update is the value 1. Note that 'b' old value at this point was 1.
    - This glitch in the second always block (from 1 it goes to 0 and then back to 1) triggers the first block again.
    If you cannot change the code to avoid the glitches, use the -delay_trigger option in situations such as the above, where two combinational always blocks that form a combinational loop connected by variables (not nets) glitch their outputs, resulting in repeated re-triggering of the blocks that reference these signals. This option causes an event control to filter out glitches that are too narrow to be seen by the event control itself, and then double-checks to see if signals in the sensitivity list have in fact changed values. If the value change created by the glitch goes away before the check (as it does for two writes in the same evaluation of another process), then the event control does not wake up, and the always block is not executed.
    This compile time switch has been documented from version 08.20-s017 of ncvlog onwards.
    NC-Verilog Simulator Help
      Compiling Verilog Source Files with ncvlog
        ncvlog Command Syntax
          -DELay_trigger
    Here is some of the description of this switch in the NCVlog Help:
    -DELay_trigger
    Filter out glitches that are too narrow to be seen by an always block event control by checking to see if a variable in the event control expression has a different value from when the block was last executed.A Verilog always block executes when an object in the event control expression for the block has changed value from when the block was last executed. This default wait mechanism is sensitive to zero-width glitches on the variables the block is waiting on. These glitches are usually created when a writer process assigns a default value to the variable and then overwrites it with a different value. Even if the writer changes the variable back to the old value, there was a change in the value of the variable before it was changed back to the old value, and that is sufficient to wake up the waiting block.
    Note: The -delay_trigger option has a small negative impact on performance.
    Note: An always @* construct that is on a statement containing an array or unpacked structure reference adds all elements of the array or unpacked structure to the sensitivity list.
    For performance reasons, the -delay_trigger option is ignored with a warning for these event controls.
    Shalom
  • Shalom B
    If you run HAL on your example, you will get the following warning:
     always @(*)
    halcheck: *W,TRRACE (./test.v,41|0): A trigger-propagation race exists between 'd' and 'b'.
    Shalom
  • Rony Ross
    Thank you for the prompt reply.
    My original code did not produce this warning. When I tried to create a small example I failed to create a clean example and this message appeared. However, Cadence's example that you posted is much simpler and does not produce this warning. As I wrote before, I strongly believe that in this case HAL warning should be generated and the simulator should not hang in infinite loop (hanging in infinite loop is usually a poor practice...).
    Rony
  • mkapil
    mkapil over 16 years ago
    Hi Rony,
    To enable race condition checks, you need to pass the switch "-races" to HAL.
    i.e.
    hal -races test.v
    Hope this helps.
    -Kapil
