  2. Logic Design
  3. ungrouping certain hierarchies (RTLC loop issue)
  • Subscribers 63
  • Views 17536
Kamal Kundu
Kamal Kundu over 16 years ago
 I am ungrouping certain hierarchies in my design. I have written a small tcl in RTLC to do so:
Suppose I have a design $Top, having hierarchy as follow:
$Top
- A (Inst name: i_A_inst)
- B (Inst name: i_B_inst)
- C (Inst name: i_C_inst)
- D (Inst name: i_D_inst)
- E (Inst name: i_E_inst)
- F (Inst name: i_F_inst)
- G (Inst name: i_G_inst)
### List of subdesigns to be preserved from ungrouping
set keep_hier_list [list A B C D]
### Preserve all the subdesigns to be prevented from ungrouping
foreach ele $keep_hier_list {
set_attr preserve true [find –subdesign $ele]
### Ungroup all instances except for those preserved as above
Ungroup –flatten /designs/$Top/instances_hier/*
Warning : Cannot ungroup preserved instance. [UTUI-100]
: /designs/$Top/instances_hier/i_A_inst
: /designs/$Top/instances_hier/i_C_inst
: /designs/$Top/instances_hier/i_E_inst
### Ungroup all the instances inside preserved modules except for some preserved ones as in loop 1
set_attr preserve false [find –subdesign $ele]
set inst_name [get_attr instance $ele]
ungroup –flatten $inst_name/instances_hier/*
### Removing preserve from these subdesigns to proceed with further optimizations
Now, when loop 2 is executed all the instances inside A except B will be ungrouped and for B it will give the following warning and come out of loop:
: /designs/$Top/instances_hier/i_A_inst/instances_hier/i_B_inst
But this is intentional because I want to preserve subdesign B (or instance i_B_inst), and I want to go to second iteration for this loop for next element.
How can I do this?
  • grasshopper
    grasshopper over 16 years ago
     Hi Kamal,
     seems to me like you could do
     ungroup -flatten $designName -exclude$keep_hier_list
    Following is the full usage information for ungroup.
    Usage: ungroup [-all] [-flatten] [-simple] [-only_user_hierarchy] [-threshold <integer>] [-exclude <instance>+] [<instance>+]
        [-all]:
            ungroups all instances under the current hierarchical instance
        [-flatten]:
            ungroups recursively
        [-simple]:
            no prefix
        [-only_user_hierarchy]:
            ungroups only user defined hierarchies
        [-threshold <integer>]:
            recursively ungroups hierarchies with cell-count less then the threshold under the current hierarchical instance
        [-exclude <instance>+]:
            the list of instances to exclude from ungrouping
        [<instance>+]:        the list of instances to ungroup
    later,
    gh-
