  2. Logic Design
  3. Getting Warning X library error detected while trying to...
  • Subscribers 63
  • Views 15688
Getting Warning X library error detected while trying to open gui for CCD
rgaddh
rgaddh over 16 years ago
I am getting the following  warning while trying to switch to the GUI mode in Encounter Conformal Constraint Dessigner(CCD)
SETUP> set gui on
// Switching to GUI mode
X library error detected: 3 - BadWindow (invalid Window parameter)
The gui is opening after the warning but it hangs. How can this be rectified
  • croy
    croy over 16 years ago
    What version are you using? The latest is 09.10-s400. If it's happening with this version please create a Service Request with support. Mention the OS and windowing environment you are running (e.g. KDE).
    Cheers,
    Chrystian
