  2. Logic Design
  3. How to tell Ambit to use one library for one module and...
  • Subscribers 63
  • Views 15453
How to tell Ambit to use one library for one module and another one for another module
ericxuo
ericxuo over 16 years ago
I would like to use 2 different libraries of standard cells in the same design. The first one (lib1.lib) would be used for the entire design except the multiplier module and its sub-modules and the second library (lib2.lib) would be only used for the multiplier module and its sub-modules.
Is it possible to do this ?
Regards.
Xuo.
  • grasshopper
    grasshopper over 16 years ago
     Hi Xuo,
    In RTL Compiler you can do
     set_attribute library {lib1.lib lib2.lib lib3.lib}  /
    regards,
    gh-
  • ericxuo
    I don't use RTL Compiler but Ambit (ac_shell).
    Anyway, I don't know what you suggest could force the synthesis tool to use lib1.lib for one module and lib2.lib for another one during the same synthesis run.
     Regards.
    Xuo.
