  2. Logic Design
  3. RTL Compiler: non_seq_setup_rising
  • Subscribers 63
  • Views 17073
moogyd
moogyd over 15 years ago
I have a memory (FLASH) element in my design that has an SE pin (basically active high read enable).
There is a setup time specified from ADDRESS to SE Active (High). This is specified in the LIB file as non_seq_setup_rising.
The question is, how can I handle or check this in RTL Compiler. SE is not a clock, but I want to check timing with refernce to it.
 Any suggestions, or pointers to app notes would be appreciated.
 Steven
  • bmiller
    bmiller over 15 years ago
     By default, these checks are checks are disabled in RC.  Set this attribute to false to enable them.
       set_attribute timing_disable_non_sequential_checks false /
    I think that will solve your problem.  If not, check that the flops driving these pins have a clock going to them.
    Brad
  • moogyd
    Hi Brad,
    Thanks for the answer, but unfortunately, this attribute is not available in the version of RTL compile I am using
     Version v09.10-p104_1
    I cannot find any reference to this attribute on sourcelink, so I am a little bit stuck.
    Steven
     UPDATE:This attribute is supported in the later version of RTL compiler (>9.1.20) so I guess I need to upgrade
  • bmiller
    RC added this attribute in 9.1.202... which is newer than the version you are using.  I suggest upgrading to a newer version.  Hopefully that will solve the problem.
    Odd that you cannot find reference to that attribute on support.cadence.com.  I searched for it, and found that it is referenced in the manuals, as well as a "Troubleshooting" article.  Be sure that RTL Compiler is part of your product preferences, or try searching in all products.
    Brad
  • moogyd
    Hi Brad,
    I found the information immediately after the first response.
     Thanks for the pointer,
    Steven
