  2. Logic Design
  3. RTL Compiler does not make use of "non-conventional" multiple...
  • Subscribers 62
  • Views 2385
RTL Compiler does not make use of "non-conventional" multiple-output cells
vdbem
vdbem over 15 years ago
I will try to be brief, but if you need any detail please ask me,
in summary, the problem is: if I describe in my liberty file a cell with multiple-outputs, the mapper (RTL Compiler) is not able to make use of it ... (if I put them together with convetional single-output cells, the tool just use the single-output cells, if I put only the multiple-output cells, it is not able to complete the mapping because does nor recognize the fundamental basic functions needed)
probable important points:
    1) There is no syntax error during the execution
    2) The logic functions of the outputs does not share inputs, an example is S1 = !(A & B) and S2 = !(C + D), so they are not like a Full-Adder..
    3) I've been using functional liberties (.lib with no information about power or timing, just the logic functions and the area set to "1"),
If I use a liberty like this one below, which is basically a cell with two "encapsulated" inverters, the tool does not even recognize the existence of inverters in the library,
  cell(two_encapsulated_invs){
    area : 1;
    pin(a){ direction : input; }
    pin(b){ direction : input; }
    pin(Z0){   direction : output;
                  function : "!a";
                  timing(){  related_pin : "a";  }
    pin(Z1){  direction : output;
                 function : "!b";
                 timing(){  related_pin : "b";  }
so my question is:
 - Is it possible to make RTL Compiler able to use multiple-output cells if they are not the "expected kind" like a full-adder?
   (in any version of it, ours is v08.10-s222_1 (32-bit), built Mar 25 2009 (32-bit), but the question is more like to know if the map algorithm is aware of such situation, or what command would make it aware)
thank you,
best regards
  • eklikeroomys
    eklikeroomys over 15 years ago
     Hi, have you found a solution to this problem? I am currently having similar problems in the design of a T flip flop which has two outputs, where one of the outputs has a combinational timing arc and acts as an enable for another T flip flop when used in a binary counter.
     Unfortunately, this is not my only concern since RTL compiler is also unable to identify the function of the T flip flop even when the combinational arc is removed from the cell.
    I used Encounter Library Characterizer to characterize the T flip flop and a .lib was written without any problems.
     Is there limitations to the types of cells that RTL Compiler is able to use for synthesis?
    Thank you
  • vdbem
    I never had an answer for that problem.. and it would still be useful for me.
    What I've been doing is mapping the design with a "conventional" library, and then recombining/exchanging cells out of RTL Compiler, by scripts, directly in the structural HDL. A very unsatisfactory flow...
    regards,
  • grasshopper
    grasshopper over 15 years ago
     Hi vdbem,
     RC does indeed support MOGs (multi-output gates) such as compressor cells, etc. However your versions is 2-3 years old and officially unsupported. I suggest you move to RC10.1.302 from http://downloads.cadence.com
    gh-
