  2. Logic Design
  3. rtl synthesis
  • Subscribers 63
  • Views 16275
rtl synthesis
vlsiproject
vlsiproject over 15 years ago
 what are the input files required for rtl synthesis using rtl compiler(encounter)???
  • manrajgujral
    manrajgujral over 15 years ago
    u need to define the technology libraries that would tell the compiler about the function, timings, power, aera etc of each gate. As of now, i am using a pre defined university library.
    and yes, you would need your .v (or .sv) file as well. :)
    I am stuck with Clock Gating analysis in my RTL synthesis. I have to reduce power of my system. and theoritically i know how to do it. but whenever i am trying to use a clock gating directive, the tool wont synthesize after that. it shows me an error about "FF_Feedback " ignored. what all do i need to speciy to the consol other thatn the lp_clock_gating true directive?
    I am at a pretty basic level of RTL usage myself, but it seems DC synthsis tool is more simpler to use in this regard.
     Well, i have my project submission 2morow, so i think i wont be getting a reply anytime soon, but would still like to know this concept.
    manraj
  • grasshopper
    grasshopper over 15 years ago
     Hi vlsiproject,
    At a minimum
    + liberty timing libraries
    + run script
    + HDL
     but depending on what you are trying to do you could need other collateral such as
     + LEF physical libaries
    + Floorplan DEF
    + capTbl
    + Yield coefficient
    + Toggle activity file
    + worst case power libraries
    + DFT related files
    No single answer here but hopefully these helps you
    Gh
