  2. Logic Design
  3. RTL Compiler: Unavoid the tiecells from library
  • Subscribers 63
  • Views 15362
haikom
haikom over 15 years ago
after I synthesized the VHDL-code using RTL Compiler 9.10, I want to insert TIE1 and TIE0 cells, but I got this error:
rc:/> insert_tiehilo_cells -hi TIE1 -lo TIE0 top_cell_name
Error   : Specify a tiecell which is not avoided. [UTUI-215] [insert_tiehilo_cells]
        : Unavoid the tiecells from library.
Can someone give me a hint, how to "Unavoid"the tiecells?
Kind regards
haikom
  • grasshopper
    grasshopper over 15 years ago
     Hi haikom,
     set_attribute avoid false [find /libraries -libcell TIE1]
     set_attribute avoid false [find /libraries -libcell TIE0]
     should do the trick for you
    gh-
