  2. Logic Design
  3. Input port associated to Clock
  • Subscribers 63
  • Views 17881
sureshm
sureshm over 15 years ago
Hi all,
Is there a way to get the clocks reaching the given flip-flop???
For Ex:  If i give a get register clock pin,  my_reg/CK , How do i retrieve the clock being propagated to this pin ?
get_attr [ get_pins my_reg/CK] clocks  in PT/DC.
how would really acheive this in RC ?
This is to identify the ports being clocked by the given clock name as i have minimum info about the input ports associated with each clock of the design and hence i would write a procedure to find the info, which requires above need?
Also, How to get only the clock pins of the whole designs instead of all register inputs pins ?
thanks in advance
suresh
  • grasshopper
    grasshopper over 15 years ago
     Hi Suresh,
     I think the propagated_clock attribute is what you are looking for
    rc:/> get_attr -h *clock pin
    Usage: get_attribute <string> [<object>+]
        <string>:
            attribute name
        [<object>+]:
            object of interest (must be unique)
        attribute categories: dft opt tim
        attribute name: hold_uncertainty_by_clock
              category: tim (controls timing optimization and returns timing information)
           object type: pin
           access type: read-write
             data type: tcl list of EnvClks and corresponding delays
         default value:
                  help: Uncertainty of ideal clock waveform edges for hold analysis.
        attribute name: lssd_master_clock
              category: opt (controls optimization)
           object type: pin
             data type: pin
         default value:
                  help: Defines the master clock port related to this slave clock port.
        attribute name: network_early_latency_by_clock
           object type: pin
         default value:
                  help: Network latency of the ideal waveform edges for early analysis.
        attribute name: network_late_latency_by_clock
           object type: pin
         default value:
                  help: Network latency of the ideal waveform edges for late-mode (setup) analysis.
        attribute name: setup_uncertainty_by_clock
           object type: pin
         default value:
                  help: Uncertainty of ideal clock waveform edges for setup analysis.
        attribute name: source_early_latency_by_clock
           object type: pin
         default value:
                  help: Source latency of the ideal waveform edges for early analysis.
        attribute name: source_late_latency_by_clock
           object type: pin
         default value:
                  help: Source latency of the ideal waveform edges for late-mode (setup) analysis.
        attribute name: user_test_receiver_init_clock
              category: dft (controls design for test)
           object type: pin
             data type: string
         default value:
                  help: User specified test receiver clock to latch data from the boundary cell.
    gh-
