  2. Logic Design
  3. Clock Gating: Pre or Post Control
  • Subscribers 63
  • Views 21725
moogyd
moogyd over 15 years ago
I am currently using lp_clock_gating_control_point set to postcontrol, simply because this was set in the the scripts I inherited.
 Are there any signficant advantages of postcontrol over precontrol?
I guess that postcontrol has a slight timing advantage, since precontrol has an additonal gate in the EN-D path.
Anything else? Which option do other users prefer or use?
 Steven
  • grasshopper
    grasshopper over 15 years ago
     Hi Steven,
    timing is certainly a difference but I believe the biggest difference is observabiliy for DFT coverage purposes. Post control limits your ability to check proper operation of the CG latch if not mistaken
    gh-
  • bmiller
    bmiller over 15 years ago
    I suggest you check your target standard cell library to determine what kind of clock gating cells are available.  In many cases only one type is available.  For example:
    $ grep clock_gating slow.lib
      clock_gating_integrated_cell : "latch_posedge";
      clock_gating_integrated_cell : "latch_posedge_precontrol";
     In this case, you would want to use precontrol.  If you chose post-control RC would be forced to build the clock gating cell from primitive components, which is obviously not what you would want.
    Brad
  • moogyd
    Brad, the library I am using contains both pre and post control integrated cells, so this is not an issue I need to consider.
    Grasshopper, I am not sure I understand your comment. I guess you mean that we will catch failts on the D input of the latch?
    Thanks for the feedback,
    Steven
