  2. Logic Design
  3. RC --- any way to dump the histogram ?
  • Subscribers 64
  • Views 1840
sureshm
sureshm over 15 years ago
 Hi all,.
 Wondering if there is any way to dump the histogram reports based on the slack, based on the modules in the Violating groups ?
 Any help in this regard is highly useful . thanks  in advance
suresh
  • mclarke
    mclarke over 15 years ago
     Hi Suresh,
      RC has a number of AE supported utilities.One of these is called report_histogram.etf which will do exactly what you want. You will need to contact your loacal AE to gain access this utility however. There is no default mechanism report in RC for this.
    Cheers,
      Mike
  • rokamura
    rokamura over 15 years ago
    Hi Suresh-san,
    I have the utility to get the slack histgram.
    You can see slack_histgram.etf file if you extract the attached slack_histgram.zip .
    Usage is :
    rc:/> slack_histgram -h
    Usage: slack_histgram [-histogram_bars <integer>] [-slack_limit <float>] [-cost_group <string>] [-save_report] [> file]
        [-histogram_bars <integer>]:
            Specify Logic Level Distribution Histogram Number (default:100)
        [-slack_limit <float>]:
            only paths with less than this slack
        [-cost_group <string>]:
            Specify cost_group if you want to see
        [-save_report]:
            Dump report timing -end result in file
    rc:/> slack_histgram -histogram_bars 200
    |      Slack               | Number | Histogram
    |   -200 =< level <     0  |      1 | ***
    |      0 =< level <   200  |      0 |
    |    200 =< level <   400  |      0 |
    |    400 =< level <   600  |      0 |
    |    600 =< level <   800  |      1 | ***
    |    800 =< level <  1000  |      1 | ***
    |   1000 =< level <  1200  |     26 | *******************************************************
    |   1200 =< level <  1400  |      7 | ***************
    |   1400 =< level <  1600  |      0 |
    |   1600 =< level <  1800  |      0 |
    |   1800 =< level <  2000  |      2 | *****
    |   2000 =< level <  2200  |      7 | ***************
    |   2200 =< level <  2400  |      1 | ***
    |   2400 =< level <  2600  |      2 | *****
    |   2600 =< level <  2800  |      0 |
    |                          |     48 | total end points
    I hope you can get what you wants.
    Okamura
    slack_histgram.zip
