  2. Logic Design
  3. Identifying Half Cycle paths in the design
  • Subscribers 62
  • Views 16781
sureshm
sureshm over 14 years ago
Hi all,
Although it may sound very trivial task, I would like to get all the half-cycle paths present in my  design, which may go for the review, using RTL ? Any hints in achieving this task ?
 Also,  if there is equivalent way of  getting attributes to the timing paths like we have it in pt_shell??
suresh
  • grasshopper
    grasshopper over 14 years ago
     Hi Suresh,
     not clear with respect to which tool you are asking but CCD is probably the ideal tool for this kind of work. More importantly, can you clearly articulate what your definition of a half-cycle path is. Does it matter if it is rise to rise or rise to fall ? Does it matter what the clock names are ? Does it have to be half cycle on some clock ? How do you define the master or not halfy-cycle path ? In other words, what would an assertion defining a half-cycle path look like ? As per RTL Compiler, you can programmatically access all data in a timing path using the -format_proc option of report timing. I suggest you work with your local AE on this since it is not documented.
    gh-
