  2. Logic Design
  3. how to uniquify the designWare in LEC
  • Subscribers 63
  • Views 16732
richardsjsv
richardsjsv over 15 years ago
Hi everyone,  when we use LEC to do check between rtl code and netlist. The DW_multi_2_stage is used in rtl code, after synthesis, the low bits of the DW output are optimized, they disappear in netlist.  And this DW is treated as BlackBox in LEC, then the LEC reports the mismatch between rtl and netlist for this BB.
Does anyone have the experience or solution for this issue.
  • grasshopper
    grasshopper over 15 years ago
     Did u try the following solution article ?
    http://support.cadence.com/wps/mypoc/cos?uri=deeplinkmin:ViewSolution;solutionNumber=11569526;searchHash=843acfe8d72306ab832a531f47a4f068
    As per uniquifying in dofile output of RC you can do
    set_attr wlec_uniquify true /
    write_do_lec ....
    hope this helps,
    gh-
  • croy
    croy over 15 years ago
    This module should not be a bbox in LEC. Are you sure you're reading in the model correctly? Also, this module will be retimed. Are you using the flow needed for that?
    Please create a Service Request through support.cadence.com so an AE from Customer Support can help you.
