  2. Logic Design
  3. RTL Compiler: how to get units for load
  • Subscribers 63
  • Views 18434
yongchen
yongchen over 15 years ago
I have set units in RC as this way: set_units -time ps -capacitance pF, I just want to read it back for double check. But I failed on command: get_attr units ..... Can anybody tell me the right way to read back current units for time and capacitance? thanks.
  • Jayn
    Jayn over 15 years ago
    Hi, You can try printing the units that has been applied in sdc as follows. The default units are in FemtoFarads and Picoseconds in RC. Based on the value being applied, the return value will include multiplier value for FemtoFarads for Capacitance and Picoseconds for time units. puts "[get_attr sdc_load_unit /designs/test_case ] fF puts "[get_attr sdc_time_unit /designs/test_case ] ps For you example (set_units -time ps -capacitance pF) , the return value from RC is rc:> puts "[get_attr sdc_load_unit /designs/test_case ] fF" 1000.0 fF rc:> puts "[get_attr sdc_time_unit /designs/test_case ] ps 1.0 ps Hope this helps.
  • yongchen
    Hi, thanks for your kind reply. I have tried the way you suggested and it works. Thank you very much.
    by the way, I have run "get_attr * * -h" and tried to find attribute for "sdc_time_unit/sdc_load_unit", but found nothing. How can you find these two attributes? Is there any hidden tips? thanks.
  • Jayn
    Hi, Yes, these are hidden attributes and hence no documentation is available. If you know the name of attribute, then you can query them in the release builds as well. Regards Jay
  • yongchen
    ok, I got it. Thanks.
