  2. Logic Design
  3. RTL Compiler: How to locate registers with unconnected reset...
  • Subscribers 63
  • Views 16037
RTL Compiler: How to locate registers with unconnected reset port
hnfq
hnfq over 15 years ago
I am currently using RTL Compiler for synthesis and have been trying to figure out a way to list all registers in the design that have unresetable registers but with no success. The design that I am working on only has synchronous reset. I am not concerned about the pipeline registers (that do not feed back into the design) but I would like to make sure that all rest of the flops do have reset port connected to sync_reset input.
Any suggestions on issue would be greatly appreciated.
  • mclarke
    mclarke over 15 years ago
    I think the best approach is to look for the know reset pin name;
    rc> find / -split -vname -pin pins_in/RST
     alternativly you can start at the root and use
    rc> fanout -end -struc [find / -pin my_source_reset_pin]
    Cheers,
      Mike
  • hnfq
    Thanks Mike.
    I am going to try both the options and see if I manage to get the desired result.
